pmovlink script
Old   July 23, 2004, 19:09
Default pmovlink script
Arnab
I have another queston. I was doing tutorial 11, 2-D Flow around 2 objects passing each other in the version 3.10. At the end of the tutorial, once I write and save Geometry file and problem file , and save and quit the window.
then they ask me to run pmovlink script and write the given commands for CFD analysis.
pmovlink
n
xm
tut
But I am using 3.15 version of star-CD on windows and I dont know where to write this script and what all should i do with the commands as i dunno how to write and run pmovlink in windows version.
Thanks in advance,
Old   July 24, 2004, 03:30
Default Re: pmovlink script
Jmjan
In STAR-CD Launcher , in "Solve" > "Star" . You have to select "Include User Subroutine" and "Moving mesh case" and then you can run solver .
Old   July 26, 2004, 04:46
HVN
The pmovlink script is only used for Unix/Linux. For Windows, you need only to use the Star-CD launcher by selecting the options you need.
HV
Old   July 29, 2004, 15:09
Arnab
Thanks for the help. Now I did as u guys said abt running star from windows and i selected user sub routines and also moving mesh case.
In the star-CD launcher it says "Running stat" but where can I see the process running?
Also in the C:\WINNT\system32\cmd.exe window it says warning : command execution error please check screen output for details
starin.f compile error
exiting starlink
f77: error switch f is ambigious
what is the problem and how can i get it fixed though it says running star. is my program running? is the simulation going on in the back ground?? Thanks in advance.. Arnab
Old   August 1, 2004, 22:50
xhliu1
Maybe you haave not install fortran lab in your system.
pmovlink varun Siemens 6 March 23, 2005 09:18
PMOVLINK and STARLINK Harendra Siemens 3 November 3, 2004 15:02
PMOVLINK for windows Bhaskar Siemens 3 November 1, 2004 21:11
How to run PMOVLINK script? Serkan Cetin Siemens 1 May 1, 2003 12:54
pmovlink problems Jerry Huang Siemens 0 June 20, 2002 20:40
