run star-applications in batch mode
Old   October 23, 2004, 09:16
Default run star-applications in batch mode
thomas
I have seen alot system calls for running star-application in the batch mode, but did not really get it! Is there any documentation for the call of star-applications (prostar & proam) under windows? I am working on winXP with Star-CD V3.150A!
At the end everything my program should do, is to start a special .mdl-file "casename" and run a script "my_commands.inp".
The main problem: by calling anyhing starting with "prostar", I am ending up in the standard Start-GUI "enter casename ..." .
Thanks for all helping hints, thomas
Old   October 24, 2004, 05:23
Default Re: run star-applications in batch mode
staruser
When you call "prostar", a batch file ($STARDIR/bin/prostar.bat) is called. In order to run the x-version (no window), you have to start pro-x (should be in your path just like prostar). The first three lines in your input file needs to contain "answers" to case name, append to echo file and resume from. An input file to create a simple 3d mesh with the vc3d command could look like this:
star1 y y !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ! beginning of prostar commands !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! vc3d,0,5,25,0,1,5,0,1,5 save,,
To start pro-x with this input you should enter:
pro-x < input
where the file input has the contense above. If you want to execute a macro, you can replace the lines vc3d and save with e.g.
ifile macroname.MAC
Old   October 26, 2004, 04:29
alex
small tip, don't call pro-x direct, call prostar x (or prostar -bat). calling pro-x directly doesn't always work (prostar points out the location of various files that pro-x needs).
Old   October 27, 2004, 06:25
thomas
Hey Alex!
The problem is that I am ending up in the star-GUI if I start the commandline with "prostar". It doesn't matter what is written behind. I would guess it is a windows problem!?
But thanks anyway, I will keep on trying! thomas
Old   October 27, 2004, 06:54
thomas
Thanks staruser,
it looks like I am getting closer.
The commands you have posted are working fine if I run them in the pdksh-environment. Starting them from the windows command-line still does not work. This time it is asking for casename etc. in the text-mode. So it looks like I have to call pro-x through this pdksh-environment, but don't know how to enter the commandline after the shell was opened. Any ideas?
cheers, thomas
Old   November 9, 2004, 07:02
sachuthananthan
whether is it advisable to use the GUI mode or the command mode to get more familiar with the star CD.Please advise me.
Old   November 14, 2004, 09:19
thomas
use the GUI-mode to get familiar with star CD. All commands you are using (also with your mouse) are recorded in the .echo-file and will be shown at the bottom of the output-window. if you are familiar with the commands it makes sense to work with the command line in the GUI-environment. The batch-mode only makes sense if you want to run your scripts without any visual out or input.
good luck, thomas
Star-ccm+ batch mode on SGE Karl Jensen Siemens 0 February 4, 2009 15:54
batch mode Peter Schaller FloEFD, FloWorks & FloTHERM 2 October 6, 2008 03:18
Batch mode in WB. cfdguy CFX 1 June 24, 2008 06:49
Star-CD batch mode error Karl Siemens 11 June 11, 2008 23:11
batch mode run hennie Siemens 1 October 3, 2002 09:13
