segmentation fault again
Old   October 27, 2006, 07:15
Default segmentation fault again
KtoTo
Excuse me for this trouble was discusssed but i didn't find needed answer (it may well be that it has been taken earlier). So, when I check one of the models (button "check all"), the error occures:
RUNNING CASENAME: amkza1 /usr/local/bin/prostar: line 99: 5230 Segmentation fault ${STARDIR}/bin/pro-${PRODR} ${CMAP} ${BATCH} ${EZTOOL} I think, this problem is extended enouph. If anybody faced with this problem or like this, please, write, what you did to solve it.
Old   October 27, 2006, 16:40
Default Re: segmentation fault again
StarSuperUser
yeah,
that is adapco programing
switch to another cfd code and you can work
Old   October 27, 2006, 17:01
Paddy
or switch to Unix/Linux
Old   October 28, 2006, 04:08
Ben
or use star-ccm+
Old   October 28, 2006, 11:22
Dave Letterman.
you can ask them:
ARE THEY COOKING BEEAAANS ?
D.L.
Old   October 29, 2006, 20:48
DB
Can you give some more detail like which software version you are using and which are you using some user programming some detail about the numerical problem that you are trying to model solver features used and BC applied.Then I can try to figure out the problem
DB
Old   October 31, 2006, 02:38
KtoTo
Hi, thanks for all answers. I use star-cd v. 3.150 (i used command ./PRO_VERSION -v for this). I obtained the mesh (about 1.400.000 cells) in pro*am from nastran file and checked it. I didn't define boundares, physical properties e.t.c. (i.e., i kept all default values).
KtoTo.
Old   October 31, 2006, 06:34
Ben
Oh my god, try using a newer version, that one was written before time began
Old   November 3, 2006, 09:25
KtoTo
))) Ok...We shall many work to earn many money....) thanks
[Technical] Segmentation fault in map msg30 OpenFOAM Meshing & Mesh Conversion 6 March 27, 2008 10:49
Segmentation fault billy OpenFOAM Installation 20 April 23, 2007 22:57
segmentation fault natesan Siemens 4 January 12, 2004 08:51
Segmentation fault Veebs Siemens 3 June 4, 2002 22:17
Segmentation fault Jose Sanchez Siemens 1 December 16, 2001 08:13
