DEM - Post Processing : Particle Mass Flow Rate
Like Tree2Likes
  • 1 Post By me3840
  • 1 Post By ping
Old   July 25, 2014, 14:22
Default DEM - Post Processing : Particle Mass Flow Rate
Yesaswi
yesaswi92 is on a distinguished road
Hello everybody,
I am simulating the flow of granular materials in a pipe using STAR CCM+. The particles are densely packed together and they are of minute size of 0.3mm. The pipe diameter is also as small as 10mm. I used DEM and Lagrangian models to simulate the problem.
But I couldn't find a way to measure the Particle Mass flow Rate through the pipe. I tried to check with the scalar plots and scalar function, but nothing worked for me.
So, it would be really helpful if anyone suggest me to find the mass flow rate of the particles across a cross section of the pipe
Thank You.
Yesaswi
yesaswi92 is offline   Reply With Quote
Old   July 25, 2014, 17:37
me3840 is on a distinguished road
You need to turn on boundary sampling to accomplish this.
yesaswi92 likes this.
me3840 is offline   Reply With Quote
Old   August 26, 2014, 16:07
Yesaswi
Thank you for the reply.
I switched on the boundary sampling and solved, but I couldn't find a way where I can find the instantaneous flow rate of the particles across a plane. I even tried with track files model, but I couldn't find the exact way of how I can find the instantaneous mass flow rate across a plan
So could you tell me what else should I do? The attached image gives the details of my problem. The particles flow out of the orifice. I need to plot a exit mass flow rate cure. So please help me out.
Thank you very much for the help.
Yesaswi
Old   August 27, 2014, 07:10
Ping
ping is on a distinguished road
one way would be to split the model into two regions with an interface at the measurement location and then use the boundary sampling there
ping is offline   Reply With Quote
Old   August 27, 2014, 15:23
Yesaswi
Thanks a lot!!
I did use boundary sampling in the way you suggested and it worked.
Thank You
dem, particle mass flow rate, post processing, star ccm+
DPM - Particle Concentration and Associated Mass Flow Rate Jeremiah Fluent Multiphase 1 April 3, 2014 04:42
Mass flow rate of phase in post mat_cfd CFX 0 September 3, 2013 07:55
Mass Flow rate in spray water modeling Behnam Ghadimi FLUENT 0 June 8, 2013 16:05
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
