Drag and Lift Coefficients In the thousands
Old   June 18, 2016, 07:11
Default Drag and Lift Coefficients In the thousands
BeginnerSTARCCM is on a distinguished road
I'm probably making a simple mistake, but I am doing simulations on a car body with moving parts (the wheels). The first simulation I ran had good results, and thus I based this second one (where I changed the body geometry slightly) pretty much too have exactly all the values of the first except where changes for to geometry and regions were made accordingly. All the factors seem to be in line, but I am getting absurd results for drag and lift.
BeginnerSTARCCM is offline   Reply With Quote
Old   June 23, 2016, 05:59
kevin alun
marmot is on a distinguished road
perhaps double check that the part surfaces are assigned to the correct boundaries in region, perhaps you set the car body part surface to the wheel boundary in the region.
marmot is offline   Reply With Quote
beginner, drag, lift
Generating the lift and drag coefficients with openFOAM JackJewell OpenFOAM 0 June 14, 2016 09:36
Can fluent get the lift and drag coefficients of the two walls (in different directio yuyuxuan FLUENT 8 January 10, 2014 20:13
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 18:31
Great lift coefficients but negative drag coefficient?! nez FLUENT 0 November 28, 2011 13:57
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 14:45
