Mesh Results Correct or Not
Old   December 28, 2016, 11:53
Default Mesh Results Correct or Not
Sidhartha Rath
sid_rath is on a distinguished road
I am doing a turbulent flow simulation (Re = 10000). I am using different mesh to see the results. Each time i am using a mesh, i am getting different results. How to know that which results is right. Is there any criteria/number which tells you that you are doing with the correct mesh. Thanks.
sid_rath is offline   Reply With Quote
Old   December 28, 2016, 11:55
Smile
Sidhartha Rath
Can cell peclet number be of any help here?
Old   December 28, 2016, 13:24
Lane Carasik
lcarasik is on a distinguished road
What type of simulation are you doing? What is the difference in the values you are using to determine mesh sensitivity?
lcarasik is offline   Reply With Quote
Old   December 28, 2016, 14:47
Sidhartha Rath
I am doing vortex shedding with suction and blowing. I am looking at COEFFICIENT OF LIFT & COEFFICIENT OF DRAG on the body to compare my result of different mesh. Generally the values converge as we increase the mesh size but in this case i am getting different different values as i am refining the mesh.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Ansys mesh for FLUENT software giving unrealistic results, while GAMBIT mesh is fine kbhamidipa3 FLUENT 0 November 30, 2012 15:52
