June 25, 2018, 07:08 |
Heat exchange (Batteries - Air)
VS
Rep Power: 7 |
Hi everyone
I have a problem with a heat exchange simulation. My system is simple: I have two Batteries (Heat source: 1500 W) and a mass flow inlet of air that is at ambient temperature (around 300 K). I have set the initial condition of the temperature for the batteries of 343 K (I have to simulate the exchange in the baddest conditions) but the problem is that if I let run the simulation there is no convergence; it's like there is no Heat Source at all because the temperature decreases until it reaches the ambient condition. Could anyone help me with this problem? |
June 25, 2018, 07:11 |
VS
Rep Power: 7 |
Here I post the images of the system.
June 26, 2018, 09:22 |
VS
Rep Power: 7 |
July 15, 2018, 23:24 |
Chaotic Water
Rep Power: 17 |
You have set Heat Source at surfaces like "Assieme con fondo modificato per CHT STAR con estrusioni 2_SOLID.Battery Pack 2" - which is ignored since it is part of the Interface and thus it's values (as a boundary condition) are ignored, it's just a heat transfer interface now.
To set up internal battery heat source: Batteries -> Physics Conditions -> Energy Source Option = Total Heat Source Batteries -> Physics Values -> Heat Source = 3000 W Keep in mind that you've chosen default Copper material for batteries (Solid Physics) - and you might need to adjust it to properties of your battery. |
moving a cold solid body into stationary hot air for heat transfer | shyamgarg | Main CFD Forum | 3 | December 26, 2019 22:41 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Air to Air Heat Exchanger | visser1975 | FLUENT | 2 | November 10, 2012 13:34 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
