error:Part Prop is not closed and Manifold, Boolean subtract |
March 5, 2017, 20:31 |
ritvik
Rep Power: 9 |
I am trying to do a propeller cfd simulation in star ccm+. I imported an existing IGS file of the propeller into star ccm+ When I boolean subtract the propeller from the rotating fluid domain and execute i get the error - 'Part Prop is not closed and Manifold' could you please suggest some solution? Best Regards, RItvik |
March 7, 2017, 12:49 |
Rep Power: 24 |
Well, it means your part is not closed, there are surface problems with it. Load the part into surface repair and see where the problems are.
March 9, 2017, 02:10 |
ritvik
Rep Power: 9 |
Thank you, Am doing that!.
Ritvik |
July 27, 2018, 07:48 |
Edge attached to an odd number of faces
Anilkumar
Rep Power: 7 |
can anyone tell me regarding surface repair? I got error part is not closed and manifold. |
August 2, 2018, 07:58 |
Owen
Rep Power: 7 |
To clarify, is the part non closed and therefore throwing an error before the Boolean operation completes? Or is it that the Boolean operation is creating a non manifold part?
Manual repair is a tool for fixing problems with your mesh, like non manifold edges. Seek out the tutorials if you want to use that tool to manually clean up your geometry. |
error when using boolean subtract | fshak92 | STAR-CCM+ | 6 | August 7, 2019 06:13 |
source not closed and manifold error while performing boolean(subtract) operation | rockydongre | STAR-CCM+ | 3 | May 24, 2019 01:38 |
[DesignModeler] Boolean subtract error-Boolean operation failed, Context:Geometry Engine | woodmark75 | ANSYS Meshing & Geometry | 11 | March 30, 2018 06:29 |
