Rad Pressure Drop Correlation Issue
Old   June 14, 2023, 21:45
Default Rad Pressure Drop Correlation Issue
Castle is on a distinguished road
I am new to CAE, start with Rad pressure drop simulation and would like to correlate to physical result, but my simulation result always lower than the physical result.
I tried increase the number of prism layers from 2 to 8, result increase a little but not too much. screen shot is the physical models i used, also simulation I set up this one inlet and one outlet, set constant inlet flow and 0 KPA for outlet
Does anyone could point out which I need to look into and change the value or any wrong on physical?
Castle is offline   Reply With Quote
Cyclone Pressure Drop Too low sirsammie72 FLUENT 6 August 22, 2020 07:56
Pressure drop and temperature issue msnadeem FLUENT 3 September 24, 2019 02:02
Pressure drop using Fan type BC Alexis Sack OpenFOAM Running, Solving & CFD 2 September 22, 2014 09:18
Mass flow rate prediction of Purge control valve using set pressure drop enr_venkat CFX 11 February 27, 2014 11:30
How to study pressure drop of continous phase in VOF model sajeesh FLUENT 4 February 5, 2014 22:01
