Home > Forums > Visualization & Post-Processing Software > Tecplot
Reading Tecplot *.plt files using TecIO.dll
Old   January 12, 2010, 21:05
Default Reading Tecplot *.plt files using TecIO.dll
sbm_dk is on a distinguished road
I desperately need to find a method to read xyz-data from Tecplot plt files. I believe Ive heard rumours that it is possible using TecIO.dll but have not yet seen a code snippet that illustrates how.
I am coding in C and C# but any piece of code in any language would be greatly helpful.
sbm_dk is offline   Reply With Quote
Old   November 14, 2013, 06:26
Default Answer
Franz
FB2012 is on a distinguished road
An example can be found in the tecio source file archive dowloaded from tecplot support. It contains two parts the tecio source code and a program called pltview.
Reading the source code of pltview will explain how to do a plt reader.
In the main part of the program just turn on array reading by modifying the following part.
Line 594 change it to
ReportFileInfo(argv[CurFile], TRUE, TRUE);
Best regards
FB2012 is offline   Reply With Quote
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 06:37
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
problem when converting mesh (made by ICEM) using fluentMeshToFoam Forrest_Lei OpenFOAM 11 October 16, 2009 06:28
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
