[ICEM] HEXA block structure smoothing
Old   October 1, 2015, 09:03
Default HEXA block structure smoothing
Klaas Slager
slager is on a distinguished road
I'm trying to smooth a blocking in a Hexa mesh (Pre-Mesh Smooth) using the Multiblock method. The idea is that vertices of the blocking are moved to get a smoothed block structure. I tried to illustrate the problem using a simple mesh of a box, see attachments for a general blocking/mesh and the desired blocking/mesh results.
However, I can't get the vertices moving using the Multiblock smoother. Anyone experience with this kind of problem and some directions how to handle the problem? Settings for Face Options, Vertices Options etc.?
slager is offline   Reply With Quote
Old   October 1, 2015, 11:04
Far
Sijal
As i know, it does not move the vertices. However it tries to make them orthogonal at their current location.
Old   October 2, 2015, 03:22
Klaas Slager
Ok, then I might have misunderstood the idea of multiblock meshing... Two new questions arise:
  • What is the purpose of the Multiblock smoothing method? And especially, what is the advantage over the Orthogonality method?
  • Is there another method to smooth the blocking like in the original example?
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 16:37
[ICEM] Hexa to Sweep block conversion pertupd ANSYS Meshing & Geometry 1 June 19, 2010 21:37
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
Hexa smoothing (ICEM CFD 10.0) CFDworker CFX 3 November 2, 2005 10:23
How to use Hexa smoothing function? Nick CFX 2 October 5, 2004 23:47
