[ANSYS Meshing] Need Help in Meshing Control
Old   October 26, 2016, 17:07
Default Need Help in Meshing Control
Shen Xinyu
jessejesse is on a distinguished road
Hi guys. I'm doint a 2D problem where two surface bodies are bonded on a shared edge. After I did the mesh I found that it doesn't have continuity on the edge. I want the mesh in which two bodies have the same nodes on the edge, is there any way to do this?
I tried with mesh connection, it looks perfect like the one I want, buy after I clicked SOLVE, it can't work.
Here is my mesh now, hope some of you may help me. Thanks in advance.
jessejesse is offline   Reply With Quote
Old   October 27, 2016, 02:01
siw
Stuart
siw will become famous soon enough
Put the two parts into a Multi Body Part in DesignModeler, this will share the edge and make a node conformal mesh.
siw is offline   Reply With Quote
Old   October 27, 2016, 03:06
Paritosh Vasava
vasava will become famous soon enough
You can introduce Match Control. See this and this.
vasava is offline   Reply With Quote
Old   October 27, 2016, 12:37
Shen Xinyu
Thanks so much. I did it following your suggestion.
Help me to choose between Ansys Meshing, Fluent Meshing or ICEM ? pipolaki ANSYS 0 December 6, 2013 08:12
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
[ANSYS Meshing] Meshing strategy for External Flows Hybrid ANSYS Meshing & Geometry 0 January 24, 2012 14:27
Line Control in Ansys Meshing Oli ANSYS Meshing & Geometry 4 November 17, 2010 15:35
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
