February 19, 2023, 05:41 |
Y+ plus Komega SST model Wind turbine .
MED
Hi guys,
I am using ANSYS FLUENT to simulate the flow and calculate the power output of a horizontal axis wind turbine. I am using the Komega -SST model. and this model gives a good agreement with a* exprimental case when the maximum y+ value is about 40.So the question is, is this value acceptable, or does it need to be less? |
February 20, 2023, 06:05 |
Daniel
Rep Power: 9 |
Whether your y+ value is good enough should be clarified through a sensitity analysis.
Did you perform a sensistity analysis regarding your mesh? That would be a good starting point to see an influence of the mesh density reagrding your power output for example. You will also see a change in y+ and whether it affects your desired output values. |
Simulation of a Wind Turbine Using an Actuator Line Model | Shelbi S | CONVERGE | 0 | April 15, 2022 12:17 |
Model turbine blades as baffles | kmallick | OpenFOAM Pre-Processing | 1 | March 21, 2017 23:40 |
RANS FX63-137 kOmega SST model | PierluigiRossi | SU2 | 2 | June 24, 2016 05:56 |
Problem with using MRF Model for verical axis wind turbine Model | rgunjegaonkar@gmail.com | FLUENT | 15 | March 16, 2016 04:28 |
Rotating wind turbine - SAS SST | Flo27 | CFX | 1 | July 9, 2015 06:51 |
