Home > Forums > Software User Forums > ANSYS
ANSYS 13 X64 Workbench problem: "Could not connect to local server"
Like Tree4Likes
Old   April 23, 2011, 11:11
Maniek
CFD-total-beginner is on a distinguished road
All problems mentioned here - as sac said - are problems with FIREWALL. I had headache with it, and when I customized FireWall everything was fine.
Disable firewall, or better: give new rule "allow All" to ansys (few files: can't say from memory).
CFD-total-beginner is offline   Reply With Quote
Old   March 11, 2012, 06:16
Mohit
mohitmech is on a distinguished road
Hi Evreyone
I have this Problem:
ANSYS, Inc. License Manager status:
Licensing Interconnect: running
Licensing Interconnect Monitor: running
FLEXlm: not running
Can AnyOne Help Me?
Please help
mohitmech is offline   Reply With Quote
Old   March 27, 2012, 09:41
Default Solution
  #23
Pranav
pranavom8 is on a distinguished road
For all of you guys there, if u have a firewall disable it and then restart the ansys this will work , or if it doesnt make sure u disable any installed antivirus, I have an eset smart security 5 and that was the culprit
pranavom8 is offline   Reply With Quote
Old   February 21, 2013, 21:36
victoryv is on a distinguished road
stop running license and then start running license in LM. Then open WB.
victoryv is offline   Reply With Quote
Old   February 23, 2013, 19:29
wcmansp is on a distinguished road
We had this problem with 14.0, Windows 7 64 SP1 -- whenever Workbench tried to launch the Geometry editor it would produce the ansyswbu error. We had not had that problem in our previous software set (using 13.0) and we had no luck exchanging pieces, changing/removing firewall settings, or the license server. Installing the 14.5 upgrade didn't change the problem. What led to a solution was re-installing Windows on top of the existing installation; this rolled back some of the core Windows files. What we found when we re-booted was a message that files related to the Cisco VPN client software had been changed. ANSYS then worked. We removed the Cisco VPN software, let the Windows Update process bring us back to the current patch level, and have not had a problem.
One theme in these error reports points to applications or tools that affect port level communication so, along with firewalls, any add-on technologies that create their own network adapters, like the pseudo-port established for a VPN adapter, may be places to start looking. We did not retrospectively check whether just removing the VPN adapter would have been sufficient -- it seems likely, though, from the fact that the file replaced by the re-install was a core file, that it would not have been; we would have needed the original Windows file back in place to get things working.
wcmansp is offline   Reply With Quote
Old   August 6, 2013, 13:46
navid
ndabir is on a distinguished road
I had the same problem with Win 7 , 64 bit for ansys 13. When I started the workbench, I couldn't see any options at the left bar to do any simulation. I restarted the computer several times but didn't work. Then I ran "Server Anslic-admin utility" as an administrator and after that I stopped license manager and started it again. Wait for couple of minutes for all components to be fully activated. Then my problem was solved. hope this helps
ndabir is offline   Reply With Quote
Old   September 24, 2013, 00:40
M.Trn
mt1359 is on a distinguished road
I had the same problem, after uninstalling my Windows7Firewall Program it is solved and my Ansys is working properly.
Originally Posted by ggc View Post
Hello everyone,
Please help me, I have a problem with Workbench. I have ANSYS 13 X64 on a Windows 7 64 bit laptop.
The installation of both the ANSYS products and the license manager went fine. The license configuration went fine as well, all three steps of the license wizard didn't show any problems and all three license managers show "Running" when I start the License Manager.
The problem is, when I start Workbench, I get an error message: "Could not connect to local server: 24800@localhost" and, on the left part of the screen of Workbench, I have no analysis options whatsoever.
Thank you, in advance, for any help.
mt1359 is offline   Reply With Quote
Old   September 26, 2013, 05:39
Mohammed
Mohd123 is on a distinguished road
It could be your internet connection or firewall restriction.
Mohd123 is offline   Reply With Quote
Old   October 3, 2013, 05:34
Jarobit18 is on a distinguished road
Originally Posted by cha65 View Post
I am running windows 7 pro x64 and have the same problem. Does any one have this problem on another version of win7 x64?
I dont have a folder called update in that directory. ansysli_client appears to have the correct path.
turn off the protection system drive (C)
Jarobit18 is offline   Reply With Quote
Old   December 8, 2013, 07:05
Default Ansys
  #30
emanuele
emanuelemarzo82 is on a distinguished road
Hi i have a problem with the istallation of ansys...i made the geometry but when i'm going to open the mesh there is the follow message : the shared license is not available to perform the geometry attach operation
Help me :-( where is the problem??? thanks!!
emanuelemarzo82 is offline   Reply With Quote
Old   December 8, 2013, 16:53
muhammad hussain
hussain_2723 is on a distinguished road
Hello everyone,
generate a new licence and then run the licence manager to install that crack . then restart the computer and the problem will be solved.
hussain_2723 is offline   Reply With Quote
Old   April 19, 2014, 05:44
Question Start the Ansys Inc. License Manager
  #32
Manaswinee Patnaik
Mana is on a distinguished road
Hello everyone,
Please help me, I have a problem with "Start the Ansys Inc. License Manager". I have ANSYS 13 X64 on a Windows 8 64 bit laptop.
The installation of both the ANSYS products and the license manager went fine. When I selected "Run the License Wizard" it shows "A valid license file already exists on this system" and after that when I continued to Start the Ansys Inc. License Manager it reads like this "Attempting to start the ANSYS, Inc. License Manager...
This may take a few seconds; please be patient...
Start the ANSYS, Inc. License Manager status:
Access is denied.
Ansys, lnc. License Manager status:
Licensing interconnect: not running
Licensing interconnect monitor: not running
FLEXlm: not running
Why this occurs and how to solve this? Thanks in advance
Mana is offline   Reply With Quote
Old   July 31, 2014, 05:30
Default hey guys, I have the same problem and now it's fixed, not sure it will work for u
  #33
junming zheng
beneon is on a distinguished road
I first encountered the 24800 thing and do as told to copy the ansysli_client.exe out from update into its parent folder, than the error message turned into something saying my licensing server is down.
then i realize my vpn to the facility is still on, after turning it off everything just fine.
and i also recalled this 24800 thing went just after i open the vpn thing, could've just solved by itself after a restart.
beneon is offline   Reply With Quote
Old   December 15, 2014, 15:07
ovunc
ovunc is on a distinguished road
I have exactly same problem and ı havent solve it yet. I tried to install Ansys 14 , ansys 14.5 but always same problem 'The shared license is not available to perform the geometry attach operation.' Does anybody know what i must do? i can do the geometry but i cant open mesh.
I solved this problem. From tools-License preferences-select use a seperate license section.Now i can open mesh but cannot open fluent. i figured out that the second problem is because of my identity has turkish characters when i changed that finally i can use fluent too.
ovunc is offline   Reply With Quote
Old   January 26, 2015, 18:02
Renato Venturatto Junior
renatovj is on a distinguished road
Originally Posted by Mana View Post
Hello everyone,
Access is denied.
FLEXlm: not running
Mana, I have the same problem you have, and the system is the same (except for the fact I'm running Ansys 15.0 and Windows 8.1)
Have you already found a solution?
Renato.
renatovj is offline   Reply With Quote
Old   November 2, 2016, 16:55
Default Had the same problem and solved it!
  #36
Muhammad
misbahmahdi is on a distinguished road
1. Open this link (if you haven't already)
http://www.ansys.com/Products/Academic/ANSYS-Student
2. At step 3 of "Installation Steps - Part 2 - ANSYS License File Installation:":
See the picture of small window?
Make sure this matches your one in every possible way.
Hello everyone,
misbahmahdi is offline   Reply With Quote
Old   March 26, 2017, 00:44
Galen
CFD Amateur is on a distinguished road
I also have similiar problem with windows 7.
CFD Amateur is offline   Reply With Quote
Old   October 26, 2017, 11:09
David Izquierdo
davidizki is on a distinguished road
I have struggled for more than a month with a kind of related problem. But it is clearly not the same -I just post it here because the error message that I got was the same, and since it is already solved I do not think it is appropriated to create a new thread-.
Note: this problem is only associated to licensing via external server (i.e. the license is installed in a server different to your computer and you just connect to it, without installing the license in your personal computer). If you have your license installed in your own computer, this problem cannot apply to you.
This is the exact message that I got whenever I tried to open the Workbench:
Could not connect to server: 1055@NAME_OF_THE_SERVER
And after more than a month talking to the customer service and trying tens of possible solutions -none worked-, it turned out that the problem was just that the .ini that is located in the folder Licensing was pointing to the server name, but the computer was only able to connect to the IP of the server, without knowing its name (DNS not properly working). And therefore no connection was possible.
Solution: substituting in the ansyslmd.ini file (in Program Files / ANSYS Inc / Shared Files / Licensing) the name of the server by the IP number (after the @). It may seem ridiculous, but I have wasted so many time with this issue... Also note that if the IP server changes, then you must change it in the .ini. The other (better) solution would be solving the DNS problems, but I have not been able to achieve that.
davidizki is offline   Reply With Quote
Old   October 7, 2018, 17:11
Default license server connectivity error
  #39
y series
y series is on a distinguished road
my disk drive c was full so i installed ansys in E directory. Now ansys is showing problem to get connection with server.
how to solve this problem ? please help .
y series is offline   Reply With Quote
Ansys Workbench Problem Andris CFX 0 September 8, 2012 14:35
[ANSYS Meshing] Problem of Mesh 2d cylinder (piston motion) in Ansys Workbench Mesh tdbbz ANSYS Meshing & Geometry 0 June 2, 2012 14:35
Ansys V13 License Server problem Gustavo ANSYS 3 May 14, 2011 21:11
solving problem on ansys 12 workbench ckdarky ANSYS 1 April 27, 2011 05:32
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 12:59
