Cfx solver manager: How to set correct y-axis value of pressure in monitor graph. |
April 2, 2014, 21:51 |
Faizan
Rep Power: 12 |
Hi all,
I set the total pressure monitor at inlet to monitor my solution during run in cfx solver manager. I set 1.4MPa total pressure at inlet but the graph is showing 0MPa. I don't know how to fix y-axis of graph? Picture is attached. I know its basic question but I am a beginner. It is very important for me. Please help if anyone know.... thanks Last edited by Mfaizan; December 17, 2015 at 22:46. |
April 2, 2014, 22:37 |
#2 | |
Rep Power: 18 |
April 2, 2014, 23:02 |
Faizan
Rep Power: 12 |
Hi antanas,
- My initial condition at inlet set to total pressure 1.4MPa with total temp 550 deg Centigrade. - Fluid model set to Total energy.(supersonic flow) - Expression for pressure monitor at inlet = areaAve(Total Pressure)@inlet Please suggest. Thanks |
April 3, 2014, 00:58 |
Rep Power: 18 |
OK. Please post screenshots of your domain basic settings tab, your inlet boundary details tab and your initialization or post CCL file.
April 3, 2014, 01:08 |
Bharath kumar
Rep Power: 17 |
Hi Mfaizan
In your screen shot it is not 0 MPa.Please click your cursor on the Monitor line to get the actual value. You can adjust your monitor point range by right click on the solver window -> Monitor properties ->Range settings ->adjust Lower bound & Upper bound Value. |
April 3, 2014, 01:13 |
#6 | |
Rep Power: 18 |
April 4, 2014, 02:29 |
Faizan
Rep Power: 12 |
dear bharat,
thanks a lot for your assistance. Yes after changing range I saw the 1.4MPa value but it I am still confused that with constant 1.4MPa total pressure boundary condition at inlet why this large negative value of pressure is appearing in the model. I checked the lowest value by putting my cursor on the monitor and it is showing -1.7e7. This is crazy. If you can assist then please explain this. One more question that how can I change the X-axis settings of the pressure monitor tab. Please reply. |
April 6, 2014, 08:27 |
Rep Power: 143 |
When the simulation is partially converged the results can show anything. Don't worry about crazy intermediate results - the final converged solution is all that matters.
April 6, 2014, 20:20 |
#9 |
Faizan
Rep Power: 12 |
Thanks ghorrocks!
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 16:35 |
CFX Solver manager runs for a long time!! | Amoul | CFX | 11 | May 15, 2013 04:05 |
CFX Solver Manager | famarcfd | CFX | 5 | June 17, 2012 19:33 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
How to obtain correct viscous pressure drag using CFX? | Ketut Utama | Main CFD Forum | 1 | January 25, 1999 05:05 |
