Formula 1 Car Front Wing High Residual Analysis
Old   January 25, 2022, 12:21
Default Formula 1 Car Front Wing High Residual Analysis
Metin
meto1992 is on a distinguished road
I'm simulating a multi-element F1 car front wing in ground effect. I'm using velocity inlet, pressure outlet, symmetry for top and side planes and finally a moving ground as boundary conditions. I managed to have validated results for certain ground clearances and my residuals were around 1e-4. I wanted to decrease the ground clearance and since I decreased the ground clearance, the velocity gradients under the wing increased a lot and this made it an unsteady analysis.
When I try to run this simulation as unsteady, the residuals decrease but it would take so long to get a meaningful result from it. When I try to run this simulation as steady, the residuals are about 1e+0 which is too high. I already did some local grid refinements and face sizing refinements too but I wasn't able to solve the issue. Do you have any ideas about how to solve this problem?
Best Regards,
Metin
meto1992 is offline   Reply With Quote
Old   February 2, 2022, 20:19
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may try to make better quality mesh
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
front wing, ground effect, residuals fluent
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 13:47
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 12:50
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 05:49
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
