Calculate the energy gain of fluid?
Old   February 23, 2017, 06:29
Default Calculate the energy gain of fluid?
Alex Moreno Bellostes
alexmb is on a distinguished road
Hi we are modelling a fluid across of pipe, inner the pipe the fluid recive a heat flux from a solid, when i calculate the energy gain of fluid =m*Cp*AT is higher than the global evaluation of heat source, It is not possible.*I don't find why when i applie a heat flux in a surface (0.0084m2) of 8000 W/m2 = 67.2W, the gain of fluid calculated by mCpdT = 83.93 *4.19*(293.97-293.16)*0.27778 is 79.12W, but if i calcule the (heat flux of outlet surface - heat flux of inlet surface) is 66.7 W similar to the heat flux =67.2 W, Do you know that I am doing wrong?
alexmb is offline   Reply With Quote
heat transfer
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 17:19
energy eqn + constant fluid properties cfx_user Main CFD Forum 1 March 6, 2013 07:13
How to specify energy source in a fluid zone? abong FLUENT 0 February 17, 2005 02:15
how to analyze mechanical energy loss of fluid? Lcw FLUENT 3 October 27, 2004 11:22
How to calculate energy dissipation chinthakindi Main CFD Forum 0 February 23, 2004 06:36
