Non-reflective boundary conditions
Like Tree1Likes
  • 1 Post By praveen
Old   October 18, 2017, 22:04
Default Non-reflective boundary conditions
nsi
nsi is on a distinguished road
Dear CFD friends!
I need to apply an NRBC to my compressible inviscid Euler eqn.s solver (shock involved problem). I tried some classical methods introduced by
Poinsot & Lele's paper
Kevin Thompson's paper
but both were subjected to numerical stability issues. I then walked through Giles's paper but could hardly understand either his philosophy or how to apply it to my solver. For example, he said the c's, i.e., {c1, c2, c3, c4} is the amplitude of the characteristic waves, but who knows how much the c's equal...
Any suggestion about other types of NRBCs?
wb
nsi is offline   Reply With Quote
Old   October 19, 2017, 08:11
Praveen. C
praveen is on a distinguished road
Boundary conditions can be tricky and it is difficult to give general answer. Can you describe the physical setup and what exactly you tried so far ?
praveen is offline   Reply With Quote
Old   October 22, 2017, 19:35
nsi
Praveen,
Attached is a cartoon of my problem set up.
I have been trying to impose a robust NRBC at both ends.
Old   October 22, 2017, 22:43
Praveen. C
If the ends are closed, then it is like a solid wall bc. If the ends are open to the atmosphere, and if shocks exit through them, then it will be difficult to give any rational bc. When shock is away from the ends, you have some external atmospheric state and you can use characteristics/riemann invariants approach. When shock is near the exit, the concept external state itself is meaningless because the shock would have changed the state on the other side of the boundary.
Have you tried a simple neumann bc, i.e., set the state in a ghost cell equal to the cell at the boundary.
FMDenaro likes this.
Old   October 23, 2017, 05:09
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
On most boundaries I tipically use the full convective scheme with ghost cells.
For your problem, a shock tube I guess, I confirm that the approach suggested by praveen (analogous to a full supersonic outlet) can work.
sbaffini is offline   Reply With Quote
Old   October 23, 2017, 07:45
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by nsi View Post
Praveen,
Have a look here for a 1D analysis and BC.s https://books.google.it/books/about/...AJ&redir_esc=y
Of course, if you are simulationg a 2D flow, it will develop reflections in the closed case.
FMDenaro is offline   Reply With Quote
Old   October 24, 2017, 03:59
Ashwani
AshwaniAssam is on a distinguished road
You may go through the Blazek book of CFD, it is a comprehensive and more direct from implementation point of view.
AshwaniAssam is offline   Reply With Quote
Old   May 22, 2019, 10:51
Mons
monika_1387 is on a distinguished road
Hi, Did you figured out how to put this NRBC BC for nozzle flow at outlet BC? Because I am trying to put NRBC BC but thats not working so trying for GILES if that works.
Can you please suggest if that worked for you? I am working on nozzle flow (supersonic at outlet end and trying to put non reflective BC at outlet.
Dear CFD friends!
wb
monika_1387 is offline   Reply With Quote
Old   May 22, 2019, 10:54
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
A supersonic outlet shouldn't need a NRBC.
LuckyTran is offline   Reply With Quote
Old   May 22, 2019, 11:17
Default Nrbc
nsi
Hi, Monika!
I would say go check Jiri Blazek's book Computational Fluid Dynamics: Principles and Applications, read the boundary condition chapter, and you will get what you need. It has a detailed description of the application of all types of B.C.s such as super/subsonic inlet, super/subsonic outlet, etc.
Best,
WB
Old   May 22, 2019, 12:08
Mons
Thank you for directing me. I ran the simulation and seeing reflected pressure waves from outlet boundary bouncing back to inlet side.. So because of that reason I believe non reflecting boundary will work. Still Let me look into this CFD book.
Hi, Monika!
Best,
WB
Old   May 22, 2019, 12:14
First of all, what about the Mach number at inflow? At the supersonic outflow the informations travels from the interior and you can use the characteristic conditions but your problem could be due to some wrong condition at the inflow. Of course a bug in the code can be also a possible cause.
Old   May 22, 2019, 12:41
Mons
Its Minlet=0.2911 (subsonic) and outlet as supersonic BC.
Old   May 22, 2019, 12:46
Are you aware of the difference of the BCs. setting between supersonic and subsonic conditions? What about the variable you are letting from the interior?
Old   May 22, 2019, 12:53
Mons
I am a new user of SU2 so learning it. But here is my attached.cfg file you can look once for BCs which I give. I am trying for NRBC, GILES or Riemann to avoid these reflections at outlet boundary. See the attached .cfg file for reference. Appreciate your comments.
Old   May 22, 2019, 13:56
Why don't you post the question in the SU2 section?
Old   May 22, 2019, 14:15
Mons
Sure. will do.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
reflective boundary conditions on generalized coor buaalzr Main CFD Forum 3 January 2, 2008 12:43
