[waves2Foam] Trying to add isoAdvector feature to waves2Foam |
August 30, 2017, 22:33 |
Chia
Rep Power: 10 |
Hi foamers,
I using OF Advector, source code that have sharper surface tracking capabilities, I'm trying to compile wave2foam via modifying interFoam https://sites.google.com/site/jordim...ic-mesh-motion I using the solver 'solver300_ext' for my attempts to compile, could it be a version mismatch? Thanks everyone for their time Code:
ddtScheme.C: In member function ‘Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::fv::ddtScheme<Type>::fvcDdtPhiCoeff(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const fluxFieldType&)’: ddtScheme.C:226:41: error: ‘dotInterpolate’ is not a member of ‘Foam::fvc’ return fvcDdtPhiCoeff(U, phi, phi - fvc::dotInterpolate(mesh().Sf(), U)); ^ In file included from fvcDiv.C:29:0, from fvcDiv.H:180, from fvcDDt.C:27, from fvcDDt.H:76, from fvc.H:45, from fvCFD.H:8, from relaxationWeightCourantCorrection.H:48, from relaxationWeight.H:63, from relaxationScheme.H:65, from relaxationZone.H:44, from waveDyMFoam.C:37: divScheme.H: At global scope: divScheme.H:78:13: error: ‘surfaceInterpolationScheme’ was not declared in this scope tmp<surfaceInterpolationScheme<Type>> tinterpScheme_; ^ divScheme.H:78:40: error: template argument 1 is invalid tmp<surfaceInterpolationScheme<Type>> tinterpScheme_; ^ divScheme.H:78:44: error: expected unqualified-id before ‘>’ token tmp<surfaceInterpolationScheme<Type>> tinterpScheme_; ^ divScheme.H: In constructor ‘Foam::fv::divScheme<Type>::divScheme(const Foam::fvMesh&)’: divScheme.H:114:13: error: class ‘Foam::fv::divScheme<Type>’ does not have any field named ‘tinterpScheme_’ tinterpScheme_(new linear<Type>(mesh)) ^ divScheme.H:114:32: error: ‘linear’ does not name a type tinterpScheme_(new linear<Type>(mesh)) ^ divScheme.H:114:43: error: expected primary-expression before ‘>’ token tinterpScheme_(new linear<Type>(mesh)) ^ divScheme.H: In constructor ‘Foam::fv::divScheme<Type>::divScheme(const Foam::fvMesh&, Foam::Istream&)’: divScheme.H:121:13: error: class ‘Foam::fv::divScheme<Type>’ does not have any field named ‘tinterpScheme_’ tinterpScheme_(surfaceInterpolationScheme<Type>::New(mesh, is)) ^ divScheme.H:121:28: error: ‘surfaceInterpolationScheme’ was not declared in this scope tinterpScheme_(surfaceInterpolationScheme<Type>::New(mesh, is)) ^ divScheme.H:121:59: error: expected primary-expression before ‘>’ token tinterpScheme_(surfaceInterpolationScheme<Type>::New(mesh, is)) ^ divScheme.H:121:60: error: ‘::New’ has not been declared tinterpScheme_(surfaceInterpolationScheme<Type>::New(mesh, is)) ^ divScheme.H:121:60: note: suggested alternative: In file included from /home/gtc/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/GeometricFieldFunctions.C:26:0, from /home/gtc/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/GeometricField.C:1337, from /home/gtc/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/GeometricField.H:655, from /home/gtc/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/GeometricScalarField.H:38, from /home/gtc/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/GeometricFields.H:34, from volFields.H:37, from relaxationScheme.H:56, from relaxationZone.H:44, from waveDyMFoam.C:37: /home/gtc/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/GeometricFieldReuseFunctions.H:79:49: note: ‘Foam::New’ tmp<GeometricField<TypeR, PatchField, GeoMesh>> New ^ In file included from fvcGrad.C:29:0, from fvcGrad.H:124, from fvc.H:49, from fvCFD.H:8, from relaxationWeightCourantCorrection.H:48, from relaxationWeight.H:63, from relaxationScheme.H:65, from relaxationZone.H:44, from waveDyMFoam.C:37: gaussGrad.H: In constructor ‘Foam::fv::gaussGrad<Type>::gaussGrad(const Foam::fvMesh&)’: gaussGrad.H:91:32: error: ‘linear’ does not name a type tinterpScheme_(new linear<Type>(mesh)) ^ gaussGrad.H:91:43: error: expected primary-expression before ‘>’ token tinterpScheme_(new linear<Type>(mesh)) ^ gaussGrad.H: In constructor ‘Foam::fv::gaussGrad<Type>::gaussGrad(const Foam::fvMesh&, Foam::Istream&)’: gaussGrad.H:104:21: error: expected primary-expression before ‘(’ token ( ^ gaussGrad.H:105:29: error: ‘linear’ does not name a type new linear<Type>(mesh) ^ gaussGrad.H:105:40: error: expected primary-expression before ‘>’ token new linear<Type>(mesh) ^ In file included from correctedSnGrad.H:153:0, from laplacianScheme.H:45, from fvcLaplacian.C:28, from fvcLaplacian.H:242, from fvc.H:53, from fvCFD.H:8, from relaxationWeightCourantCorrection.H:48, from relaxationWeight.H:63, from relaxationScheme.H:65, from relaxationZone.H:44, from waveDyMFoam.C:37: correctedSnGrad.C: In member function ‘Foam::tmp<Foam::GeometricField<Type, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::fv::correctedSnGrad<Type>::fullGradCorrection(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) const’: correctedSnGrad.C:53:9: error: ‘linear’ was not declared in this scope linear<typename outerProduct<vector, Type>::type>(mesh).dotInterpolate ^ correctedSnGrad.C:53:9: note: suggested alternative: In file included from surfaceInterpolateTemplates.C:28:0, from surfaceInterpolate.H:170, from fvc.H:39, from fvCFD.H:8, from relaxationWeightCourantCorrection.H:48, from relaxationWeight.H:63, from relaxationScheme.H:65, from relaxationZone.H:44, from waveDyMFoam.C:37: linear.H:52:7: note: ‘Foam::compressibilityModels::linear’ class linear ^ |
February 27, 2019, 16:23 |
Possibly a solution (CANNOT GURANTEE IT WORKS)
Akshay Patil
Rep Power: 10 |
I think I managed to couple this. However, I must admit I have no idea if it makes any sense. I just tried to copy paste a few files here and there and compile it. It seems to be working. Could you confirm if it works the way isoAdvector should? Thank You! |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[waves2Foam] New wave theory coded in FORTRAN, how to add to waves2Foam? | Kun_zheng | OpenFOAM Community Contributions | 6 | August 30, 2017 04:58 |
[PyFoam] and paraview | eelcovv | OpenFOAM Community Contributions | 28 | May 30, 2016 09:23 |
add two area around Cylinder in ansys | sajjadcheraghian | CFX | 1 | May 24, 2016 01:23 |
