[OpenFOAM.com] paraFoam Failing to Get Current Screen Resources |
February 20, 2019, 16:21 |
#1 | |
Alec
Hello!
I'm pretty new to Ubuntu and Openfoam, and I am currently trying to get the first Openfoam tutorial to work. I am running Ubuntu 18.04 on Windows 10, Openfoam6, Paraview5.4/5.6 (more on this later), and I have Xming installed for displaying a GUI when I use paraFoam command I have followed the instructions for installation from the Openfoam website, and everything about Openfoam seems to work nicely: blockMesh and simpleFoam both work perfectly. However, when I use the command "paraFoam" it returns this: Code:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-neil' failed to get the current screen resources Xlib: extension "MIT-SHM" missing on display "localhost:0.0". paraview 5.6 on Ubuntu 18.04 (Windows 10 WSL) This user has the same problem as I, and another user responds saying: Quote:
I followed his instructions, replacing paraviewopenfoam56 with paraviewopenfoam54; however, if I try to run paraFoam I get this: Code:
FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PVReaders ./Allwclean ./Allwmake Code:
paraFoam -builtin Code:
Created temporary 'pitzDaily.foam' /opt/openfoam6/bin/paraFoam: 278: /opt/openfoam6/bin/paraFoam: paraview: not found Thanks! |
openfoam, openfoam 6, paraview 5.6 |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 14:33 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 07:48 |
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] | u2berggeist | OpenFOAM Installation | 2 | July 2, 2018 17:03 |
Dynamic_cast failing while postprocessing with paraFoam | gschaider | OpenFOAM Bugs | 3 | August 20, 2010 16:37 |
paraFoam / paraview black screen | gfilip | OpenFOAM | 6 | July 13, 2009 04:30 |
