[snappyHexMesh] how to get both parts ?
Like Tree1Likes
  • 1 Post By Harak
Old   February 5, 2011, 07:28
Default how to get both parts ?
Tobi's Avatar
Tobias Holzmann
Hey all together,
i wanna mesh that : picture teg
everytime i mesh it with sHM i got the wrong side : picture wrong - its like i need the negativ from it :/
I solved it but overwrite the case and don' t know how my settings in snappy were :/(
I ve done several settings but don 't get the geometry
if i set the location point into one part of the geometry i just get one of the part not both?
some idea ? it should be possible ... or not ?
Help.
Tobi
Old   February 5, 2011, 07:55
Retired Super Moderator
Bruno Santos
Hi Tobi,
OK, now I'm confused... do you want:
  1. The mesh inside both box geometries. This would be a bit odd, since you would need to connect them somehow...
  2. The mesh outside of the boxes.
  3. A mesh that has the outside and the insides of both boxes.
If "b", then just increase the outside mesh box in blockMeshDict and define in snappyHexMeshDict a point closer to the end of this outer box. This way you'll be sure to catch a point outside of the boxes
If "a" or "c", see the tutorial "heatTransfer/chtMultiRegionFoam/snappyMultiRegionHeater", since you'll be dealing with multiple mesh regions, each one requiring a well defined way of exchanging physical values...
By the way, be sure that the STL geometries don't have any leaks. AdMesh can help with that.
Best regards,
Bruno
Old   February 5, 2011, 09:16
Tobi's Avatar
Tobias Holzmann
hi bruno hope i can clear your confusion.
first i am using chtMulti - so i need several parts of regions.
I had a look at the tutorials and its all clear if i have to mesh "one" geometry. : picture
its just a little extract. Okay so far ...
In the middle i have the parts i wanna mesh.
The STL file includes all boundary conditions.
Don 't know how i should explain it. ... hmm.
Okay if i mesh one part its no problem.
But in the middle i have 2 or 3 or 4 or 10 parts of the same behavior . So i wanna mesh all parts of the same behavior to get one region for all those parts in the middle.
Is it clearer now ?
Tobi
Old   February 5, 2011, 13:17
Bruno Santos
Hi Tobi,
Mmm, I'm still having trouble understanding you Possibly it's because I'm tired from the week, so my brain is very slow today
OK, as far as I can understand, you have two unconnected blocks in a single STL. And you want to generate a mesh inside them and outside them, correct?
Well, my experience with multiple regions is limited, but I think that you'll need to resort the same scheme as the tutorial case "snappyMultiRegionHeater". In other words:
  1. you must have 1 STL file for each box;
  2. you must have additional STL files/boxes for the volume you want to use for interfacing with those two boxes.
Only then will you be able to properly defined the regions outlined by your geometries! Otherwise, if there isn't any connection between those boxes, sHM will very likely ignore one of them, because sHM was designed for creating a single contiguous volume.
When it comes to separating the mesh into various regions, splitMeshRegions is used, according to the faceZones/cellZones identified in snappyHexMeshDict.
The working sequence is outlined in Allrun in "snappyMultiRegionHeater".
Best regards,
Bruno
Old   February 5, 2011, 14:11
Tobi's Avatar
Tobias Holzmann
Hi
first - thanks a lot.
Ehh i just wanna hava a mesh inside both parts.
Meshing every region part sperate not in a whole STL like the heatTransfer snappy tutorial, couse if i do that i got "for example" for the parts in the middle
30 different parts.
first is correct -> name region = teg
second ... domain1 . domain2 ...
but its okay. I think i can 't do that.
Thanks for your help. My english skills are not as good as it should to give an implicit notice what i wanna do.
A nice weekend.
Tobi
Old   February 16, 2011, 07:22
Tobi's Avatar
Tobias Holzmann
Okay - its not possible to get all regions in one step. I 've split it to several domains like you said and now it works
Now i know how to do it.
thx Tobi
Old   February 17, 2011, 17:14
Bruno Santos
Hi Tobi!
I'm glad you've finally got the handle on this meshing issue
You might consider useful to learn a bit of bash scripting and how to use sed and grep, in order to make the whole procedure faster to do and use
Best regards,
Bruno
Old   January 9, 2012, 06:32
Aqua
aqua is on a distinguished road
thx Tobi
Hello Tobi,
I have been struggling with the multiRegion SHM for a long time. I have two stl files: iblock.stl and oblock.stl. They are two cubes next to each other. I want to create mesh inside both the two cubes. But the mesh is always not correct.
such as :
Cellzones:
iblock size: 38975
oblock size:0
Could you please, if possible, send me your case?
Thank you so much!
aqua is offline   Reply With Quote
Old   January 9, 2012, 09:01
Tobi's Avatar
Tobias Holzmann
Originally Posted by aqua View Post
Hello Tobi,
Cellzones:
iblock size: 38975
oblock size:0
Thank you so much!
Hi Aqua,
i think you have the same problem like I had a time ago.
Are your Meshparts connected? If not you have the same problem.
My chtMulti Case is no more avaiable :/ sorry.
But maybe in my backup. I 'll have a look at my hard disk today evening, hoping to find it and send it to you.
Tobi
Old   January 9, 2012, 10:09
Aqua
Hi Aqua,
Tobi
Hi Tobi,
thank you so much for your help!
my problem is, after running snappyHexMesh, only the file "iblock" has the file "polyMesh" which contains the iblock mesh. But in the file "oblock", there is no such a file named "polyMesh"......
Thank you again!
Aqua
Old   August 11, 2015, 13:00
Harak is on a distinguished road
thx Tobi
Hi Tobi,
it's been a long time since you solved the problem but I'm having exactly the same problem now.
I understand that I have to have one stl file for each geometry but I don't understand the next steps..
I would really appreciate it if you could help me
Danke
efalpha likes this.
Harak is offline   Reply With Quote
Generate Parts Using Named Selection jonasohlsson ANSYS 1 March 14, 2016 04:32
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts a.habibi ANSYS Meshing & Geometry 5 October 4, 2012 05:10
How to handle suction and pressure side of an airfoil as two different parts? TKE ANSYS Meshing & Geometry 4 March 17, 2011 06:49
Creating 100 derived parts / Splitting derived parts for mass flux calculation xamo STAR-CCM+ 8 September 29, 2009 05:35
[snappyHexMesh] SnappyHexMesh complex geometries amp thin wall parts hsieh OpenFOAM Meshing & Mesh Conversion 0 September 22, 2008 17:34
