[Gmsh] Boolean operation in Gmsh?
Old   June 22, 2011, 11:21
Default Boolean operation in Gmsh?
Robin
wwrfd is on a distinguished road
Hi everyone,
I have been adviced to use Gmsh instead of Gambit to make an OpenFOAM study, the interface is great and looks like Gambit however I was wondering if there were any possible operations such as doing the instersection between two solids. For exemple if I have two cylinders crossing each others and I want to delete the intersected part inside the volume, how can I do that? (I know there is a split function but it is not available for surfaces).
Thank you for your answers and the CFD online community.
wwrfd is offline   Reply With Quote
Old   August 17, 2011, 09:46
Hansjoerg Seybold
hansjoerg is on a distinguished road
No,
cheers hj
hansjoerg is offline   Reply With Quote
boolean, cylinders, gmsh, split
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so immortality OpenFOAM Pre-Processing 15 April 7, 2024 12:35
[Gmsh] Gmsh Boolean Subtraction on .stl Files f_mdi2 OpenFOAM Meshing & Mesh Conversion 0 October 5, 2018 15:22
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
Info message -> Fluent does not start Jenson FLUENT 0 December 22, 2011 17:21
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
