icoFoam's pressure possion equation.
Old   July 15, 2013, 03:49
Default icoFoam's pressure possion equation.
Dongyue Li
sharonyue is on a distinguished road
Hi
In icoFoam we have:
fvScalarMatrix pEqn
                    fvm::laplacian(rAU, p) == fvc::div(phiHbyA)
But via my equation(see the image), Shouldnt it be
fvScalarMatrix pEqn
                    fvm::laplacian(rAU, p) == fvc::div(HbyA)
Thanks
sharonyue is offline   Reply With Quote
Old   July 16, 2013, 03:30
Dongyue Li
div(phiHbyA)?
\nabla \cdot a
Im confused about this divergence of a scalar thing.
Old   July 16, 2013, 21:34
Dongyue Li
I changed it to
fvScalarMatrix pEqn
It compiles successfully and works in cavity and elbow case!And the solution is almost the same with
fvScalarMatrix pEqn
                    fvm::laplacian(rAU, p) == fvc::div(PhiHbyA)
Whats the problem..
fvc::div(HbyA):dimensions      [0 0 -1 0 0 0 0];
internalField   nonuniform List<scalar> 9(0.157469 -0.0674757 -0.487085 -0.960691 0.789192 0.715649 30.1762 0.258981 -30.5822);
fvc::div(phiHbyA):dimensions      [0 0 -1 0 0 0 0];
internalField   nonuniform List<scalar> 9(-0.435688 -0.0982547 0.152804 -0.0448476 0.720155 -0.152663 28.2072 0.236062 -28.5848);
Old   July 26, 2013, 12:39
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, check the p-U coupling section (2.7) in my Ph.D thesis. It will also give you some pointers to good material on this topic.
Link to the PhD thesis is provided in my user page at openfoamwiki.net: http://openfoamwiki.net/index.php/User:Santiagomarquezd
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
Last edited by wyldckat; May 24, 2016 at 17:35. Reason: repaired link and description to link
santiagomarquezd is offline   Reply With Quote
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 15:00
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? renyun0511 OpenFOAM Programming & Development 0 November 4, 2010 01:38
Pressure enigma. Sara Main CFD Forum 22 July 30, 2009 04:46
pressure Poisson equation in fractinoal step metho Rui Main CFD Forum 6 October 15, 2000 04:57
