Tube with cylinder inside in OpenFoam
Old   August 8, 2015, 19:44
Default Tube with cylinder inside in OpenFoam
orxan.shibli is on a distinguished road
There is a solid irregularly shaped cylinder inside a tube. Fluid flows through the irregularly shaped tube and the cylinder. In other words, the radii of tube and cylinder are not constant. One end of the tube is closed while the other end is open. The tube is flexible and its boundary condition is moving wall. When the tube is squeezed inside 1 cc fluid should come out through the open end. This is similar to squeezing a tooth paste but with a solid cylinder along the center of the tube. The fluid is Newtonian and similar to water at body temperature, flow is laminar Which openfoam solver should be used? So far I think pimpleDymFoam is the closest. How should I set the moving wall? Is there an example link to refer?
orxan.shibli is offline   Reply With Quote
Old   September 6, 2015, 11:53
Retired Super Moderator
Bruno Santos
Quick answer: tutorial case "incompressible/pimpleDyMFoam/movingCone"
cfd - post, openfoam 2.1.x, tube in tube
moving piston inside cylinder saeidhomayounslm Main CFD Forum 0 July 21, 2014 03:13
What is best mesh for cylinder tube? olivia FLUENT 7 January 16, 2014 05:55
boundary condition inside a cylinder mohsen Khandan OpenFOAM Pre-Processing 0 April 10, 2013 05:24
simulation of piston motion inside a hydraulic cylinder mosman Main CFD Forum 0 August 7, 2011 01:40
OpenFOAM vs Fluent for cylinder at Re%3d150 lr103476 OpenFOAM Running, Solving & CFD 40 December 18, 2008 09:09
