Error when running through Slurm
Old   April 18, 2019, 08:17
Default Error when running through Slurm
Sita Drost
sita is on a distinguished road
I'm using OpenFOAM-5.x on a Scientific Linux cluster. Everything works fine, I can run simulations no problem, but when I try running a job through Slurm, I get this error:
/opt/OpenFOAM/OpenFOAM-5.x/etc/config.sh/bash_completion: line 6658: `_rm~all_': not a valid identifier
I noticed that this error has been reported as a bug, and fixed in both OpenFOAM-5.x and OpenFOAM-dev (https://bugs.openfoam.org/view.php?id=2823). Does anyone have any idea why it still pops up when using Slurm, and how to fix this?
Many thanks!
Sita
P.S. For now I've removed the _rm~all_ bit from bash_completion, which rids me of the error, but I'm not sure whether this will get me into trouble at some later point
sita is offline   Reply With Quote
Old   April 25, 2019, 07:43
Retired Super Moderator
Bruno Santos
Quick answer: It looks like your OpenFOAM 5.x installation isn't based on the most recent commits, because the bug report you mentioned is implying that it was fixed in this commit: https://github.com/OpenFOAM/OpenFOAM...a32d2a2deca208 - in which, yes, the "rm~all" script was simply removed, along with the associated auto-completion entry.
Old   April 25, 2019, 11:49
Sita Drost
Thanks! To be honest, I don't know what commit that OpenFOAM-5.x install was based on, as I didn't install that one myself. But it looks like I can safely do without this script, great.
Old   April 25, 2019, 13:55
Bruno Santos
The help argument with any OpenFOAM application should give the build with version and commit that was used to build things, e.g.:
blockMesh -help | grep Build
With luck you get something like this:
Build: 5.x-68e8507efb72
but if it was downloaded as a ZIP package, you will only get something like this:
Build: 5.x
It should also appear on the header of the runs, e.g.:
|  \\    /   O peration     | Version:  5.x                                   |
Build  : 5.x-68e8507efb72
Exec   : blockMesh
Date   : Apr 25 2019
Time   : 18:55:30
Old   April 25, 2019, 14:51
Sita Drost
Cool, never really noticed that before, I'll give it a try.
Thanks!
Sita
Simulation just stops output writing, but keeps running blaise OpenFOAM Running, Solving & CFD 6 March 27, 2024 04:49
Error problem while running sadia d lts tutorial kane OpenFOAM Running, Solving & CFD 2 May 26, 2018 03:38
Error Running Design of Experiments in ANSYS Fluent tytrzecki FLUENT 0 April 22, 2018 15:01
Problem in running coarse mesh(on the other hand fine mesh is running) ashokmoravaneni OpenFOAM 7 July 17, 2017 04:56
parallel running openFoam-1.5-dev lulo OpenFOAM 3 October 3, 2011 11:42
