[OpenFOAM] Paraview 3.98 - errors when saving geometry file
Old   September 12, 2013, 04:45
Default Paraview 3.98 - errors when saving geometry file
Stephen Bosch
pajot is on a distinguished road
When I try to save a geometry for an OpenFOAM case that includes a couple of slice filters and an STL terrain file, I get this error:
  ERROR: In /var/tmp/portage/sci-visualization/paraview-3.98.0/work/ParaView-3.98.0-src/VTK/Common/ExecutionModel/vtkDemandDrivenPipeline.cxx, line 816
 vtkPVCompositeDataPipeline (0x4540a60): Input for connection index 0 on input port index 0 for algorithm vtkXMLPVAnimationWriter(0x3aa61f0) is of type vtkMultiBlockDataSet, but a vtkDataSet is required.
 vtkPVCompositeDataPipeline (0x4540a60): Input for connection index 1 on input port index 0 for algorithm vtkXMLPVAnimationWriter(0x3aa61f0) is of type vtkMultiBlockDataSet, but a vtkDataSet is required.
Any ideas? It could be harmless, the geometry files do get generated...
pajot is offline   Reply With Quote
Old   September 28, 2013, 10:45
Retired Super Moderator
Bruno Santos
Greetings Stephen,
Sorry for the late reply, but the information you've provided isn't enough either
Therefore, a few questions:
  1. What file format are you trying to save the data/geometry to?
  2. The error message mentions animation... how exactly are you trying to save the data/geometry? Because it seems like you're trying to save all time snapshots.
  3. Are you able to reproduce this error with one of OpenFOAM's tutorials? Such as "incompressible/simpleFoam/motorBike"?
    You'll have to uncompress the file "constant/triSurface/motorBike.obj.gz" before opening it on ParaView.
Best regards,
Bruno
geometry, vtk
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
