Can’t fix pierced faces
Old   July 1, 2019, 20:04
Exclamation Can’t fix pierced faces
Ian
cgswjs is on a distinguished road
Hi everyone,
My name is Ian and I’m working on a CFD project of a counter flow double pipe heat exchanger. I have a DPHE model with 75c water in the inner tube and 27c air in the outer shell. There are also 6 helical gear vortex generators in the annulus region. I got my model working in star cam, however, the temperature results are way off. The software is giving me 4000C on the Vortex generators. I think it has something to do with the pierced faces I didn’t fix for the vortex generators. I did surface repair and it fixed most of them. But there are 106 pierced faces on the vortex generators it couldn’t fix. Is there a way that I can fix them manually? I created my model in solidworks btw. Can someone help me with this? Thanks a lot!
cgswjs is offline   Reply With Quote
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 07:48
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 13:38
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
