Applying vibrations to pipe
Like Tree2Likes
  • 1 Post By ping
  • 1 Post By ping
Old   January 19, 2021, 23:31
Default Applying vibrations to pipe
Joseph
jseamon1 is on a distinguished road
Hello All,
I am new to STAR-CCM and am really struggling to figure out how to go about setting up this simulation. Basically, I want to set-up a simulation where I have a flexible pipe which has water flowing through it and oscillates up and down. I should also add that for this simulation I am not really interested on the interactions between the water and the pipe but rather just how the flow changes as the pipe oscillates transversely. Based on what I have learned from about STAR-CCM so far, it seems that the morphing motion with a custom field function would be the best way to go about this, but I cannot for the life of me get anything to work. Is there something I am missing? Has anyone else attempted a similar scenario? Thank you all for your help in advance!
PS: This link -> https://www.acs.psu.edu/drussell/Dem...ing/Fixed.html
demonstrates the type of oscillatory motion I hope to impose on the pipe/fluid domain.
jseamon1 is offline   Reply With Quote
Old   January 20, 2021, 08:58
Ping
ping is on a distinguished road
the tutorial Tutorials > Solid Stress > Fluid-Structure Interaction: Vibrating Pipe is a good starting point and just ignore all the solid stress stuff and its region and apply the required motion to the pipe wall boundary in some sort of field function as a vertex velocity probably
jseamon1 likes this.
ping is offline   Reply With Quote
Old   January 20, 2021, 10:50
Joseph
Ok, great! I will look at that, thank you! Is there any documentation or tutorials on creating vertex velocity field functions that you could point me towards?
Old   January 21, 2021, 00:16
Ping
this tutorial gets you quite a long way to what you need: Tutorials > Motion > Morphing: Cylinder with Boundary Motion
but you will need a more complex field function that includes $Time in the formula to create harmonic motion. and i would consider using one of the other morpher displacement spec. methods called 'total' probably rather than velocity
Old   January 21, 2021, 13:57
Joseph
Ok, great! I will give that a shot. Thank you!
Old   February 1, 2021, 21:16
Joseph
Thank you all for your help! Those tutorials were extremely helpful and I was able to get the vibrating motion I was looking for. Thanks again!
morphing mesh, morphing motion
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
need help about double pipe heat exchanger with chtMultiRegionSimpleFoam wuyangzhen OpenFOAM 10 December 12, 2017 00:19
Applying boundary conditions for vertical rotating pipe. pranaychowdary FLUENT 0 May 1, 2016 10:04
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
