Parameter for a good meshing
Old   December 18, 2019, 07:42
Default Parameter for a good meshing
Alessio Mancini
Aliosha86 is on a distinguished road
Hi guys,
my name is Alessio. I am struggling at deciding whether a mesh is good or not. I would not like to do a parametric study and I would learn to see if the mesh is looking good or not just looking at parameters such as Aspect Ratio, Jacobian, skewness etc..
Can someone give me rules of thumb to see if I get a good mesh?
Cheers,
Alessio
Aliosha86 is offline   Reply With Quote
Old   December 18, 2019, 10:46
Stanley90 is on a distinguished road
Originally Posted by Aliosha86 View Post
Hi guys,
Cheers,
Alessio
Apart from what application and for which CFD solver this mesh is being created, I'd check skewness at first. You can do it easily in ANSYS Meshing for already created mesh. Just create named selection and choose worksheet instead of geometry. Then go to worksheet table -> right click in Action column -> Add -> Entity Type = Mesh Element ->Criterion = Skewness -> Operator = Greater Than or Equal -> Value = e.g. 0.95 -> Generate. You should see then mesh elements with skewness greater than desired value. By worksheet in named selections you can make many other check of mesh e.g. like stairsteps.
Stanley90 is offline   Reply With Quote
Old   December 18, 2019, 11:33
Lucky
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
1) Resolution (in areas you care about)
2) Skewness (skewness and non-orthogonality cucks all computations)
3) Growth rates / stretch ratio / volume change. (i.e. smoothness)
That's plenty. Most grids don't even satisfy the first criteria.
LuckyTran is offline   Reply With Quote
Old   December 20, 2019, 14:25
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
The more regular it is the better. Yet, resolution is really case dependent. Just changing viscosity would change your resolution requirements.
sbaffini is offline   Reply With Quote
aspect ratio, jacobian, mesh
[ANSYS Meshing] Cant get parallel meshing to work in V18.2 jones007 ANSYS Meshing & Geometry 17 November 9, 2020 05:56
Map of this Meshing (sub-)Forum wyldckat OpenFOAM Meshing & Mesh Conversion 0 April 27, 2019 09:33
[ANSYS Meshing] Parallel meshing utilisation failing crc1622 ANSYS Meshing & Geometry 0 February 14, 2019 02:42
Looking for some good meshing literature and tutorials BilalUsmani Lounge 2 July 11, 2017 12:48
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
