Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Salome - Geometry
Old   July 23, 2018, 05:51
Default Salome - Geometry
Thuraya
Thuraya is on a distinguished road
after installing Salome Salome-V8_4_0-univ_public on Ubuntu 18.04 I faced this problem where I cannot enter new entities like 2D /3D sketch The error message is:
GUI library corresponding to the users action can not be found or loaded.
the terminal has the following message too.
Warning: module HEXABLOCKPLUGIN is improperly configured!
Module HEXABLOCKPLUGIN will not be available in GUI mode!
Warning: module HYBRIDPLUGIN is improperly configured!
Module HYBRIDPLUGIN will not be available in GUI mode!
Warning: module BLSURFPLUGIN is improperly configured!
Module BLSURFPLUGIN will not be available in GUI mode!
Warning: module HexoticPLUGIN is improperly configured!
Module HexoticPLUGIN will not be available in GUI mode!
Warning: module GMSHPLUGIN is improperly configured!
Module GMSHPLUGIN will not be available in GUI mode!
Warning: module NETGENPLUGIN is improperly configured!
Module NETGENPLUGIN will not be available in GUI mode!
Warning: module GHS3DPLUGIN is improperly configured!
Module GHS3DPLUGIN will not be available in GUI mode!
Thuraya is offline   Reply With Quote
Old   September 2, 2018, 04:51
Default same problem here
Stefan Karrer
siliconverter is on a distinguished road
I installed salome meca 2018 on a ubuntu 18.04 which was freshly installed.
I had to install python 2.7 and gcc and install libcanberra-gtk0 libcanberra-gtk-module
finally net-tools.
Also disable 3 faulty drivers at $HOME/salome_meca/V2018/prerequisites/debianForSalome/lib/libstdc++.*
Now Salome Meca 2018 starts with the following warnings:
stefan@ubuntu-engineering:~/salome_meca/appli_V2018$ ./salome
runSalome running on ubuntu-engineering
Searching for a free port for naming service: 2810 - OK
Searching Naming Service + found in 0.1 seconds
Searching /Kernel/Session in Naming Service +++++Warning: this type (SALOME_MED/MEDCouplingFieldDoubleCorbaInterface,objref) already exists, it will be ignored.
found in 2.5 seconds
Start SALOME, elapsed time : 2.7 seconds
Would be nice if someone had a suggestion on how to resolve these Warnings.
siliconverter is offline   Reply With Quote
geometry, salome
[ANSYS Meshing] CATIA Geometry Generation and Meshing danielsullivan ANSYS Meshing & Geometry 0 April 3, 2017 21:11
[Salome] unexpected geometry : topology of source and target faces seems different salome 6863523 OpenFOAM Meshing & Mesh Conversion 8 March 9, 2017 04:24
[Salome] how to create geometry with salome to make "IdeasUnvToFoam" working! amorenelchino OpenFOAM Meshing & Mesh Conversion 5 June 24, 2013 10:35
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
[Salome] Salome Geometry question (Pipe with certain wall thickness) Hectux OpenFOAM Meshing & Mesh Conversion 1 April 8, 2009 06:44
